Mar 05, 2018Explorer II
garry1p wrote:The meter uses the internal battery to generate a reference voltage. If the battery is too weak the reference will be low, causing a higher than realistic reading.
The internal meter battery is used for the display and ohm setting only. If the display looks good the meter should be good to go for battery testing.
Replace the battery and retest.
