navegator
Oct 05, 2014Explorer
Our RV has two methods to get water, one is the manufacturers hose connection and the other one is a gravity feed that I installed and has a lock, although it is on the same side as the fuel inlet it is a lot higher and definitely different than the gas cap which also has a lock.
Senior moments do happen to all not just us old folks.
Then they are called young moments.
We used Dawn for cleaning the radiator and cooling systems on the fire engines when the head gaskets blew and oil got pumped into the cooling system, I also clean the black water tank every 6 months since human waste is more grease than anything else.
navegator
navegator
