23hotrodr
Apr 04, 2016Explorer
cbeierl wrote:
You shouldn't have to remove the hinge. Inspect the lower front and rear corners for a few screws holding the panel shut (instead of the latches all of the regular doors have). Removing those screws should allow the panel to hinge up. You will need to support it with a broomstick or something, however, since it won't have any gas cylinders supporting it.
I know how to open and support this door. I really want to remove it completely so it is not in conflict with the slide while working on the water heater.
I was really hoping someone out there was familiar with how Winne hinged these compartment doors and the trick to removing them at the hinge. There is not so obvious to me a trick for doing this.
38,769 PostsLatest Activity: Apr 03, 2026
