CVDExplorerJun 27, 2014How To Replace Water Tank Drain Valve?My fresh water tank is leaking out the drain. I assume the knife valve is no longer “tight”. Can I simply remove the 4 screws around the drain outlet and pull the valve assembly out? I’m not sure w...Show More
Related ContentWater Heater Replacement RecommendationsAirstream fresh water tank drain valve replacementWater Heater Bypass Valve - How To ReplaceReplacement furnace valve? Removing valve?Voltage Dump Valve Replacement
