rk911
Apr 28, 2015Explorer
Bill.Satellite wrote:
This is the lock I use and it's simple and works great. Made by the LAMP Company. It sounds like you might have a French Door setup with 2 doors and a drawer so it may or may not work for your setup (you would need 2).
clicky
The other thing used successfully is the spring loaded push latches like this.... clicky
They can be installed in the gap between the top of the drawer and the frame in most cases (use 2) and one or 2 can be installed on each door to keep them closed while driving and still easy enough to open.
