- rockhillmanorExplorer IITo confuse you all more!
If you travel a lot to different areas or sporting events you will eventually run into a shore station that will not have the outlet you need. That is why they sell dog bones and adapters.:W - DrewEExplorer III
Wijames wrote:
rv2go wrote:
50 on left-30 middle 20 on right
Do some C's have 20 amp service?
None that I'm aware of, at least none of at all recent vintage. Possibly some pop-ups and similar small trailers have 15/20A service rather than 30A service.
The 20A outlet is required by the NEC at all campsites with electric service. It is useful for using appliances and such at the site without having to go through the RV wiring. (Actually, I don't know offhand if it technically requires a 20A circuit or if a 15A circuit and receptacle would also be acceptable. The difference is not of great practical importance since pretty nearly nothing has an actual 20A plug with the one prong horizontal.) - WijamesExplorer
Do some C's have 20 amp service? - rockhillmanorExplorer II
rv2go wrote:
50 on left 30 middle 20 on right
X2
Look at the plug on the end of your power cord.
You will most likely have a 30 amp RV. That would fit in the middle outlet in the pix above.
this is a 30 amp plug
- RoyBExplorer IIIAdditionally most trailers I have seen also has a STICKER next to the 30A or 50A Shore Power Cable Door that tells you what SERVICE the trailer has been setup for... (30AMPS or 50AMP)
photo from google images - rv2goExplorer II
50 on left-30 middle 20 on right - WijamesExplorer
CloudDriver wrote:
A 30 amp plug has three prongs, a 50 amp plug has four.
Thanks, that makes it easy. I love this forum! - Matt_ColieExplorer IIWilliam,
Are you asking if the Park has 50amp service?
If they don't say on their website, you have to call and ask.
If you are asking if your coach is 30 or 50 amp?
Count the pins on the shore power plug. 3 = 30, 4 = 50
Matt - CloudDriverExplorerA 30 amp plug has three prongs, a 50 amp plug has four.
38,778 PostsLatest Activity: Jun 10, 2026
