ron_dittmer
Mar 28, 2015Explorer III
navegator wrote:That's what I was thinking.
What amount of fuel is in the vehicles fuel tank, if it is 1/4 or less the generator will not run, fuel line to generator is at the the 1/4 level, easy to forget, check the amount of fuel...
In our rig, it's 1/3 tank, not 1/4, so anything below 1/2 tank, I'd fill up to make sure that is not your problem.
And I also agree with the others. Stand outside with the generator cover off and listen while your mate is holding in the prime button. No sound means something has gone wrong. On my generator, there is a duplicate primer button right on the generator so if you have one, you can test and listen outside by yourself.
