MountainAir05
Feb 16, 2014Explorer II
If you have a volt meter, then check voltage with engine running with the red lead on alt output. Should be close to 13+ volts. Now have someone run the engine up and voltage should jump up to close to 15. As long as the voltage does not stay stable then the alt is good.
