fcooper
Feb 19, 2014Explorer II
bluebarry1964b wrote:
UPDATE: I did some experimenting. For some reason, as one person mentioned, when I have the generator and engine on, the "alternator" light is, indeed, coming on. When I shut the generator off, but keep the engine on, the "alternator" light is going off.
What I can't figure out is why now? I've had the RV for 8 years and never encountered this problem before. The one change is that I just replaced all of the chassis and house batteries. I did look over the wiring and it looks like the batteries were hooked up properly.
Any ideas as to what could be causing this now?
I've been researching this lately since my coach only has a relay delay that works in one direction.
Holiday Rambler/Monaco used several devices over the years to try to keep both sets of batteries charged. Sounds as if you have the bi directional relay delay device (BIRD) that does not have the lead that inhibits operation of the relay tying the batteries together if ignition is on and the generator is on.
Here's what I think is happening:
The BIRD sees alternator input, see's the chassis battery set is charged, and closes the Big Boy (or other) relay tying the chassis batteries and the house batteries together so that you can get your house batteries charged while driving down the road.
This is all well and good, but now you decide you need the generator running so that you have 110 volts for some reason. Now the inverter/converter sees 110 volts and begins to provide power to the house batteries....but the house batteries and the chassis batteries are still tied together because the relay is closed. The inverter/converter and the alternator are now BOTH trying to charge both sets of batteries.
Someone that understands electronics better than I do can probably explain better why you're seeing the dash light under this circumstance.
One model of the BIRD (INTELLITEC RV/MOTORHOME BI-DIRECTIONAL RELAY DIESEL MODEL: 00-00839-000) has a 12 volt lead from the generator that allows the BIRD to inhibit the operation of the relay. Here's Intelletic's description of the operation:
"When the generator is operating, a 12 volt signal is applied to the generator input. This inhibits the isolator from
operating. This is to prevent the generator/converter combination from supplying power to the chassis functions which might over-load the converter or the generator circuit breaker."
As to your other question Why is it diffent now? Maybe the battery install cleaned up some bad connections, or maybe one set of your batteries were so bad the BIRD never energized the relay (of course I'm guessing here).
I hope this limited info helps.
If you start looking for your BIRD, some of them are circuits mounted on the large fuse/relay board in the electric bay. Some of them are mounted (I think) near the batteries themselves. My one directional isolator relay delay is mounted in the battery bay.
Fred
