enblethen
Dec 24, 2020Nomad
Look for a switch on the bottom of the thermostat. Depending on thermostat it should be in "heat".
Does the fan start up? If it does, it may take several cycles to clear air from line being replaced by propane.
Is the propane on? Operate stove top to insure you have good propane flow.
38,773 PostsLatest Activity: Apr 25, 2026
