Grit_dog
Dec 26, 2020Trailblazer
time2roll wrote:dradeng wrote:Still seems odd that you only had heat when running the generator. This would happen if the battery was dead or disconnected and the converter that supplies 12 volt power was only powered by the generator.
turned out to be the battery disconnect switch was turned off. Thanks all for the help!!
Battery on or off the heat should still work if plugged in.
I am afraid you might be running just on battery power. That is fine until the battery is dead. Check the voltage on the battery now so you don't lose power in the night. 13.2+ volts you are fine, 12.6 or lower and your time is limited.
Saaaay wut?
