map40 wrote:
DON'T FALL FOR THE LOW MILLAGE TRICK!!!!!!!
I have an RV rental company. They only units that work well are the ones that have been used regularly. I have sold units with 300K miles ex-rentals and they are still rolling around.
I have bought units with more than 100K miles, ex-rentals, not one mechanical problem. As long as they were maintained propperly.
All the units that I got with low millage for their age ended being a money pit. New appliances, new hoses, new seals, so on and so forth.
Look for signs of water damage, specially in the cab over.
Maintenance records are important. I always look at the little things. Light the burner cover in the stove, see how clean it is. Look at the steering greasable joints, check they are not dry. Age of tires and condition. Brand of oil filter used, how clean are the battery connections. Basically, little things that tell me the owner took good care of it. A new air conditioner is $600. A new transmission a year from now is going to be $4000.
If it was propperly maintained, I would not doubt buying a high millage RV. The V10 and the Ford transmission will do over 200K with no problems if it was excercised and used.
That was my inclination as well. If it's a 2012 unit with 10K miles, for me, that's a red flag in some respects. If it has 60K miles, at least you know the owner was out on the road with it.
