fireflock
Aug 10, 2015Explorer
Depending on where you mount it, you might consider a spacer between the unit and the material it's mounted to.
For example: http://forums.motorhomemagazine.com/index.cfm/fuseaction/thread/tid/27477968.cfm
Mine has been mounted to thin wood for ~4 years (inside a cabinet). It also gets a hot spot where the relay is mounted. It's probably no big deal, but it discolored the wood a bit so I added some spacers to help air flow and dissipate heat.
Other than that, it's been a great unit that I would buy again.
38,766 PostsLatest Activity: Jan 10, 2026
