Buster52 wrote:
I have a 1989 Southwind with a P30 chassis. I am having a problem with my hydraulic jacks and need a manual for it. But I cannot pin down witch model it is. It is self leveling. It has 7 switches, 4 controls the jacks, power, horizontal/vertical and retract. I checked the control and pump and no info other then HWH on the control box. Thanks
Is the control panel square and are the switches plastic type toggle switches? If so, you have a obsolete "paddle switch" control system. Can you post a pic of the switch panel? Probably the 400 series. Paste this link and look at the 400 series. Doug
http://www.hwhcorp.com/ml7879.pdfhttp://www.hwhcorp.com/ml40256.pdf
