dougrainer
Apr 25, 2013Nomad
ThorResidencyNewbee wrote:
Thanks for the replies. I did look at the valves on top of the unit. I have a total of 8 (4 for the jacks and 4 for the 2 slides). However, there is only a "T" handle on the back and the wires going in. No hole or adjustment spot. One thing I forgot to mention is that even when the electric motor is running, there is no fluid being moved by the pump. I took off a U shaped tube on the top that directs fluid to the shuttle valve and there was no fluid in it, leading me to believe that the pump isn't doing anything even though the motor is spinning.
READ What I stated. Doug
