dougrainer
Apr 26, 2013Nomad
ThorResidencyNewbee wrote:
Thank you to everyone that has responded. I will try to check out the motor to pump engagement as was described and see what is there. In regards to the Harbor Freight pump gauge, where does it attach to test the pressure?
Thanks again for all the help.
AT the shuttle valve. BUT, if you just crack the shuttle valve nuts and engage the motor and NO fluid blows out, you have no pump pressure. The working pressure of HWH is 2900 to 3300 psi. Doug
