jmponde's avatar
jmponde
HWH leveling problems
I have a 2007 Winnebago Adventurer. Gas rig. The leveling system isn't working. I have a pull out switch for the parking brake. With the engine running, I can hear it working like it should.
I've set the brake and put the transmission in park. No lights come on the leveling panel. If if push one of the buttons, a light come on indicating I have not set the tranny in park and or the parking break is not on. Other lights on the dashboard indicate they both are in the correct position.
There is a small flashing light behind the control panel.....does this indicate something? I've looked at the HWH web site and find no solution. I've called, but it's 2-3 weeks before I can get technical help.
The system I have is the HWH 625 model as best I can tell.
Any suggestions?
  • If the HWH panel shows no parking brake set, that means the HWH system does NOT see the Chassis parking brake switch. That indicates that from the chassis Parking Brake switch to the HWH system that wire is not connected. You state you have a pull out PB. Does that mean you have a Workhorse chassis? Doug
