mike_brez's avatar
mike_brez
HWH slide no work
I have a single slide wont go in or out. Air leveling. Pump does no run not even a clicking noise to be heard. I tried the trouble shooting guide that is on line but no luck. I have power from the slide room key. My extend/retract switch has power on the middle two contacts. If I flip the switch while using a test light to ground and touching either the top or bottom contact and press switch the test light will light for a milli second and that's it. I have power at the pump and pressing the switch in either direction cuts that power to pump. I installed a new switch and it does the same thing.
  • take a 4 gauge or larger jump wire from the Battery cable feed at the pump assbly to the Motor cable lug. The motor should run. If it does NOT, then the 12 volt pump motor is bad. Doug
