FLHTCI's avatar
FLHTCI
Hydraulic stabilizers down during storage
Hello all,
What’s the consensus on leaving your stabilizers down while in storage?
Ive heard it’s 4 more ways for mice to get into the coach. I also heard it keep some of the weight off of the tires minimizing flat spots on the tires.
Thank you
  • The only real downside I ever thought of when leaving jacks down for storage, is if there is a problem with your jacks when you go to take it out, you are stuck. But I guess better to know in storage than while on a trip. Any RV I ever had, the jacks will lose a small amount of pressure and relax. Hardly noticeable in a month, but in 3 months it could be several inches. My FW has been in storage for 2 months and we took it out last weekend. I didn't think about the jacks dropping and almost hit the bed rails on the bottom of the nose of the FW. And I know you are asking about MH's, but on FW's at least 2 of the jacks are always down (you can't store it any other way) and I have never heard anyone complain of any problem. And they are the same jack systems used on MH's.
  • Not a huge issue either way but I would lean toward raising them:
    - Flat spots on the tires are more an issue from 40-50yrs ago. Modern tires are much more stable.
    - Hydraulics will be under pressure, so lots of time to leak (but really a low risk).
  • wildtoad wrote:
    Inflate tires to sidewall pressures. Don’t forget to reset pressures later. Also good time to give tires a good bath.
    Please explain.
    Thank you
  • Yes, use the jacks to take weight off tires and suspension. Inflate tires to sidewall pressures. Don’t forget to reset pressures later. Also good time to give tires a good bath.
  • when my coach was not being used I supported the frame with jack stands to keep the weight off of the springs as well as the tires. I was on a concrete slab.
    I have to think that most full timers keep their levelers down most of the time.
