OLYLEN
Jul 11, 2016Explorer
Just use jumper cables from the Coach to chassis batteries and you could go a long way. or use a cloths pin to keep the emergency start switch active. If a converter makes 12 volt supply from 120 and an inverter makes 120 from 12 volts why is a inverter/converter not the same as an inverter/charger.
LEN
LEN
