YC_1
Jan 31, 2015Nomad
Ok, take a breath. Nothing you did would cause a serious issue except reversing wires on the stereo might cause its fuses to pop. Your battery ran down while you were messing about and that caused the stereo issue at first.
If you have a generator or a charger then get the engine battery fully charged.
If you were tying wires into the fuse box you could have blown an ignition control fuse. Since you can smell fuel and it turns over fast enough to start then you are missing spark. Sometimes fuses can fool you too.
If you find some device on the fuse block that looks like it is used to tap a wire off it could be highly suspect. Some of those devices spread the fuse holder contacts and even though fuses are good you lose power. Use a simple 12 volt test light to check each end of every fuse. A test light is less than $10 in many cases. Don't use a voltmeter because they can fool you.
38,763 PostsLatest Activity: Dec 05, 2025
