rockhillmanor
Feb 08, 2015Explorer II
holstein13 wrote:rockhillmanor wrote:I found two smoke detectors and checked both batteries. The smoke detectors emit a loud chirp when the batteries are low. I've checked the batteries and ruled out the smoke detectors.
Propane detector and CO detector. They are hard wired in. The sound echoes thru out the MH very hard to figure out where it is coming from.
Especially if it's the propane one near the floor.
Been there did that. Embarrassed to say it took me over a week to track it down.
Those 2 hard wired detectors will beep if there is even the slightest low voltage detected. It is a built in feature on these detectors for your safety.
My coach battery was on it's way out.I don't believe I've got any CO detectors.
I'm still looking for one, but I wouldn't think I've got one since we don't have any propane appliances or a propane tank on this coach.
I don't know if the manuf puts in propane detectors in DP's or not BUT:
I would find it very difficult to believe that your 2015 Newmar King Aire 4599 does NOT have a carbon monoxide detector which IS or SHOULD BE hard wired and does have a built in low voltage alarm(beep). The lowest of low end coaches all do.
And if you don't I sure would install one! :W
