Jim
Dec 11, 2015Explorer
Jim & Betty wrote:Gjac wrote:
When mine leaked it was also in cold temps. Look in back of the WH there should be two lines with fittings on them one for hot and one for cold. Wrap a paper towel around each one, and hand tighten the one that is wet. Let us know how you make out.
Ditto on this same thing happened to me more or less turned out to be the outlet where the anti-back flow device is.
JimR
Another "Ditto" on checking and tightening the fittings. Mine also had a minor leak that turned out to just be a loose fitting.
