zach477
Dec 11, 2015Explorer
Gjac wrote:
Zach is this in a MH? If so if you open the baggage door next to the WH you should be able to look at the backside of the WH. You may need a flashlight and a mirror it may be very tight. Can you access the backside of the WH? You can't get to it from underneath.
Yes it is in a MH. However, the only way to access the back of the WH is from underneath. I crawled under today and there is a hatch on the bottom side. I spent more time than I want to admit trying to get it open. The screws were so caked in gunk from being on the underside of the coach that you couldn't even tell they were screws. One was especially stuck/stripped. I ended up just drilling it out and was finally able to acces the back of the WH.
All of the hoses and fittings look good and were dry. The leaking is coming from the front of the WH. On the front there is the black faceplate (I guess that's what you could call it) and it has a hole cut out where the drain plug is. If I push down just below the drain plug, I can get a little water to seap out.
