Gjac
Dec 11, 2015Explorer III
zach477 wrote:Yes Zach you are right it should not leak under pressure. But there is still some pressure until the water cools. You could lift the handle to release the pressure. You said it appeared to leak right under the drain plug. Are you sure it is not leaking from the plug it self?
If it were to be an air pocket issue, wouldn't it only leak when it was turned on and heating up? Mine will leak even if it has been off for a day.
