RayChez
Dec 19, 2015Explorer
zach477 wrote:Jim@HiTek wrote:
There's another thing that causes the random pump operation...you know the two showers most RV's have?
If the gate valves are ON and the head valve is OFF, that could make the pump run periodically. Check both the bath tub shower head and the dog washer out in the wet basement compartment.
I always turn the shower water off completely otherwise it drips from the shower head.
The random pumping is definitely a lot less frequent now that I have stopped the WH from leaking.
It might have helped, but you still have a leak some where. The pump should not start if your lines are tight.
