jhilley
Feb 22, 2014Explorer
katoomer wrote:
I would like to put wifi with my own internet connection in our coach. But it's not that easy for me. I need at least 2 LAN ports for my Sonos music system and a NAS to store music.
I also need the capability to change out wifi providers. I need one for Canada ( I use Telus)
and then maybe Verizon or whomever for U.S.A.. Must be capable of handling numerous devices. The bit of research I've done has me looking at a Cradlepoint Router that will connect to a MIFI hotspot. I'm just not sure if it will allow me to change hotspots back and forth when I cross the border. I'm had enough of RV park wifi and data roaming fees.
Any suggestions?
Your CradlePoint router solution will work fine. Just make sure it is one that has Wifi as WAN capability. I do the same thing and use a CradlePoint CTR-35 and a Novatel 4620LE Jet Pack from Millenicom on the Verizonwireless network. The CTR-35 only has one Ethernet port, but you could connect a small switch to it.
