Sam_Spade
May 28, 2017Explorer
Bordercollie wrote:
I was reminded not forget and leave the house battery disconnect switch in storage position indefinitely as the house battery will self-discharge.
IF.....you are connected to shore power.....AND you have a good 3 or 4 stage converter/charger, there likely is no reason to EVER operate the battery disconnect switch. That is for use when there is no shore power OR it is known that a cheap charger will be worse than no charging at all.
