Frankedj
Aug 09, 2014Explorer
With 20 years of experience in construction you know that you will find the unexpected. Using one of those saws to cut through ceiling and wall panels without knowing exactly what is in that ceiling or in that wall can cause considerable damage to wiring that might be in there.
You will also have to add additional framing at every cut edge to have a surface to attach the new panel to. That is also going to reduce the structural integrity of the whole unit. You would be better off to pull out the cabinetry and replace full panels with full panels. If you want your repairs to last you should do them as close to original as possible if not stronger. Never go the route that will be weaker or do it because it is easier. You will end up paying for it in the long run with a job that needs to be done twice instead of once.
Styrofoam insulation is what you were thinking of.
38,766 PostsLatest Activity: Jan 10, 2026
