Executive45
Mar 16, 2020Explorer III
I'd go with the 5000/5300 springs. In order to determine the correct psi for your tires, we'd need the tire size. You've already given your estimate of your weights. To be more accurate though, I'd wait until I was ready to go camping and have the coach weighed then. I usually weigh mine at a Flying J when I fuel up. $11 and you have accurate axle weights. Then simply look at the chart and air up or down accordingly. I've linked the chart below. Airing to the max will jar your teeth.....Dennis
Inflation tables
Inflation tables
38,769 PostsLatest Activity: Jun 25, 2013
