CA_Traveler
Mar 17, 2020Explorer III
way2roll wrote:X2 Then use the mfg load inflation table for your tires.
The proper way to get weights is to load your rig for travel - fuel, water, food, people, clothes, tools, chairs, bbq, the list goes on and on. Why?, because that's your actual weight when you travel and that is what matters for being over/under and determining proper PSI. You just wasted your time and now you are guessing - which you could have done without weighing it. Why bother to do it if you aren't going to do it properly?
Actually the "best" way is to weigh all 4 corners, then use the weight for the heavest side on a axle to set the psi for all tirea on that axle. You could have a side to side weight problem that can be corrected by moving cargo.
38,769 PostsLatest Activity: Jun 25, 2013
