dougrainer
Jul 06, 2014Nomad
luvdoggiez wrote:
Ok, so I do have water flowing to the ice cube trays if I jumper from a 110 outlet to the water valve. I stuck a VOM meter on the control wires from the ice maker to the water valve and never saw any voltage as the ice maker cycled through. So, I would concur there might be something wrong with the ice maker. Do you folks concur or do you think there might still be an issue with the 'Heater tube'?
Thanks in advance! - Eric-
IF you had a problem with the feed line to the icemaker tray, you would have either NO water to the tray or a lot of water leaking down behind the refer. REPLACE the Icemaker assbly. That will fix your problem. Doug
