- Kayteg1Explorer III use other factors to determinate preventive maintenance or just carry part.
I DIY everything so labor is not an issue, but living in CA and frequent Las Vegas very often I am 150 miles from closest good shop on 120F desert.
So question would be if I would be able to work around hot engine in 120F direct sun.
Belt is easy in this, but lot of CPS require sliding your arm on the side of engine and those have nasty habit of going without warning. - wolfe10ExplorerPart of the "use old belt for spare" vs "buy a new one and let it age out" depends on how difficult it is to install the belt.
On our side radiator coach, belt replacement takes 3-4 minutes. But, on some rear radiator coaches, it takes two people and considerably longer.
This SHOULD factor into the equation. If labor (yours or pay someone else) is easy, stick with the used one. If labor is very time consuming/expensive, carry a new one.
I have no problem with either answer. - Tom_BarbExplorer II
hacker7 wrote:
THROW THE OLD BELT AWAY. IF YOU ARE GOING TO CARRY A SPARE BUY A NEW ONE. MANY ARE NOT EASY TO DO. WHY DO OR PAY TO HAVE IT DONE TWICE.:@
It's better to have an old belt than nothing. I must order them, as will any one broke down in remote areas.
buy a new belt now, and wait 5-7 years to use it?? Does that make sense? - DSDP_DonExplorerWhen both my coaches were new, I didn't carry a belt. As soon as I got near the five year mark, I bought a new belt to keep as a spare. They're inexpensive if you buy a Napa replacement. Typically around the 6-7 year mark the belt was replaced.
- hacker7ExplorerTHROW THE OLD BELT AWAY. IF YOU ARE GOING TO CARRY A SPARE BUY A NEW ONE. MANY ARE NOT EASY TO DO. WHY DO OR PAY TO HAVE IT DONE TWICE.:@
- nemo45Explorer
wolfe10 wrote:
The answer is totally depends on the engine and what the chassis maker drives off the serpentine belt.
Our first two DP's had a separate belt driving only the water pump. Serpentine belt ran the alternator and A/C compressor.
Our current coach's serpentine belt drives water pump and alternator, with a separate belt for A/C compressor.
Please check YOUR owners manual for the information on YOUR coach.
Wolfe10 is absolutely right. It depends on your engine. I just had the serpentine go on my Cummins ISL 400 last week. The water pump quit and the engine overheated almost immediately. The A/C still worked and I'm not sure about the alternator because I shut it down right away. I called Freightliner and they couldn't give me the part number of the belt as the serpentine belt is on the engine delivered. Luckily the mechanic found a piece of the belt with the number on it. I don't see much sense in replacing you belt before it goes. Except for the two hours we spent waiting for the tow, we didn't save anything as we have Good Sam Roadside Asst. I sure as hell couldn't have replaced it myself. However, it is a good idea to keep a spare belt and probably an idler pulley too. - Tom_BarbExplorer IIHaving a spare, this is good, knowing how to replace the belt is golden.
- bluwtr49Explorer IISince the serpentine belt on my C-12 only turns the alternator and AC compressor I'm not overly concerned as I can do quite nicely without them by running the gen set as necessary.
That said, I will replace the belt every 3-4 years as a PM item. - Canadian_RainbiExplorer
Tom/Barb wrote:
That depends upon what is being driven by the belt, usually the dash air quits, the engine water pump quits and the engine over heats.
OBTW, the belt may be cracked, but in no danger of breaking. most belts have a backing that is the belts strength, the rubber grooved portion it for traction over the pulleys.
Agree. Good plan on your part to change it. And keep the old one (or buy a new one) for a spare. HERE is what happened when ours broke in southern Mexico some years ago. - rockhillmanorExplorer II
Took almost a week to get it from Cummins NW.
Bought a new MH and at same time bought a 'new' belt to keep on board. Everyone of my vehicles has a spare new belt on board. Toad too.
A little bit of insurance which prevents a lot of headaches breaking down without a replacement.
38,778 PostsLatest Activity: Jun 05, 2026
