ronfisherman wrote:
Welcome to Class C's.
Now you need to update your Signature.
I have searched and can't remember how to change my signature.
Someone remind how please.
I will answer some questions from others here as well.
I sold the Horizon locally before buying the Freelander.
I have had a large 5th wheeler so I hopefully will remember the overall height.
I am a bit confused on the length. Paperwork says it's a 22TB (twin bed).
Actual floor inside from rear wall to stepdown into cab is 17 feet.
Then two more feet to base of doghouse (doghouse if that is what it's called in a Sprinter).
It says 20.3 gallons on the propane tank and has a Guardian RV 3.4KW Propane generator.
A lot to learn about the Coachman part and the Sprinter chassis.
For instance I plugged it into a 20 amp circuit and the A/C didn't work so I had to move it to the back yard and plug into my 50 amp circuit.
The Wife is still figuring out where to put stuff. Way more room than the B plus a bunch of outside storage.
The learning process continues.
Marvin
PS, Thanks for your support.
PPS, Does anyone else have a Freelander on the Sprinter chassis?
