danix's avatar
danix
I'm buying one (surprise)
I am not a trailer/camper/motorhome person, but with COVID going on, you can't even rent one of these things nowadays. So, when I came across one for sale today, I spoke to the seller and put down a deposit.
It's a 2005 Itasca Spirit 24V, 26k miles, one owner. I know the tires are shot, but otherwise seller says everything works (but couldn't get generator to start, couldn't get water to flow, as it hasn't been used in a couple of years.
I'm trying to find a local RV place to look at it on Monday, and I have a list of things to check from friends who own RVs.
Anything else I can do to make sure I'm not making a big mistake here? I haven't even driven it, mainly going off the vibe on the seller, a retired doctor who used it for trips with his family.
Any suggestions would be welcome. The engine and mechanicals are familiar to me as I had a F250 with the same V10 engine and I think transmission as well. It's the other things I know little about.
  • Generator needs more than 1/4 tank of gas to run, check gauge.
    Safety feature so you can't park and run out of gas.
    Water, either fitting broken from freeze or drain open still open. ???
  • I’m doing a similar rehab on a very low mileage Forest River class C.
    Feel free to contact me.
  • Water intrusion in the roof and walls is probably the most common problem. Particularly in the cab over bunk area. Have a good look there, and get the roof examined for cracked, missing, and dried out caulking around the seams of everything up there.
