Dale_Traveling
Jun 25, 2021Explorer II
My one repair I worked from the inside and duplicated the original wall sandwich of materials as best I could with available materials. Fiberglass exterior, 3/16" tempered board, 1" ridged foam insulation and final interior 3/16" tempered board.
Each layer is held in place with two part epoxy. Used a lot of epoxy but I also looking at the epoxy as a water proofing as tempered board and water can be a problem. With a bit of luck the repairs will out last the coach. The hardest part was coming up with a clamping plan to hold everything in place for 24 hours while the epoxy set up.
Pictures of the project. The leak was at the stove vent.
Total Boat 2 Part Epoxy Kit
