Hank_MI
Sep 30, 2017Explorer
As a note, the chassis battery is probably good. The converter via shore power can't supply enough current to start the engine so it must be drawing current from the chassis battery. Neither the converter nor the battery disconnect solenoid are designed to handle the current of the starter. That's why I suspect the chassis (Main) disconnect is off or the disconnect solenoid is bad.
38,771 PostsLatest Activity: Apr 22, 2026
