Solo's avatar
Solo
Impression of New Shocks and Sway Bars on E450
Just recently decided to take the plunge and install new aftermarket shocks and sway bars on our 2005 Winnebago Aspect 23D on a 2004 Ford E450 chassis. A lot has been reported on this subject already and I researched extensively before making the decision. I really did not think that the handling of this particular coach was bad before. We bought the Aspect new and have about 25K miles on the original chassis parts but, wondered if I could make it better. I thought others might benefit from my experience and so here's my take on the installation and then of course the driving result. We just recently got back from our first trip out after the installation and put about 1000 miles on the parts over various types of driving.
What I installed (tried to make the best choice for my application and use from what I read others doing):
Hellwig 7180 Rear Bar and 7008 Front Bar
Bilstein 174534 Steering Stabilizer, 176857 Rear Shocks and 187570 Front Shocks
Installation
Let me start by saying that by profession, I have been teaching automotive technology for nearly 4 decades and have worked as an auto tech and also in the Ag equipment business and so this is not my first rodeo. However, I decided to approach this as any "do-it-yourselfer" might try. I did not use anything special that most would not already have in their typical home garage. I even decided to leave the motorhome sitting on the ground for the entire installation of everything, simulating what anyone could do in their driveway. As a matter of fact, I did everything myself even though it would have been nice to have had a third hand and a bit younger set of muscles!
Sway bars. Removal of the original Ford bars front and rear, very straight forward. Nothing difficult here. Installation of the Hellwig bars, again not bad at all. The rear bar is heavy and bulky and so someone helping here would have been appreciated.
Shocks. If you have never installed heavy gas charged shocks before, get a little help here. Do your research, watch YouTube clips on tricks to getting the shock compressed while installing and so forth. Rear shocks, not bad. Fronts, again, not too bad here either. The top nut on the driver's side takes patience but, a ratcheting box wrench does a good job. I've been involved in much, much worse before.
Driving Impressions
Low speed maneuvering over uneven areas like cornering through dips at intersections made the coach move a lot before. Not as bad as our old gasser class A on the P-30 "bread truck" chassis, but far from SUV quality. We're from Kansas and so wind is something that we deal with regularly. Side wind gusts before, two hands on the wheel at all times when gusts went above approx. 20mph. Correction on the wheel would often times be nearly a constant 45 degrees in strong side winds-not a real comforting feeling but, when you need to make miles you take chances I guess.
After installation-Low speed maneuvering drastically improved. No more rocking and rolling during cornering. Prevented nearly 75% of the leaning. Ride quality, I actually think the HD Bilsteins took the harsh feeling out of bumps. Don't forget, we are on a 450 chassis with a fairly short coach. I've heard some suggest to not use the HD shocks but use the "Comfort" model instead. For us, the HD works very well. Side winds-I hit side gusts of 40mph as we came across Northern Missouri and Kansas on the trip. No more 45 degrees correction! Pleased with that improvement. Actually could "one-hand-it" on the wheel with those gusts and truck traffic. No way could we have done that before. Highway speed cornering-very predictable. Handled the Ozark mountain two lane roads with nice confidence.
Overall, good decision to install the parts. Does the motorhome handle like an "SUV" now, well not like most I have driven but, still worth the cost of this upgrade. I highly recommend doing this and would do it again on any E450 coach that did not have this done. Most confident do-it-yourselfers should be able to do this on their own.
Next up, my wife is tired of doing the Lego block leveling thing and asked, "isn't there something else?" That's all I needed-I have placed my order for Quadra Big Foot Leveling System.
I know many are already saying, "you don't need this on a short coach like that!" I will remember that the next time I pull up and level with the touch of a button while I watch you get your blocks out during the driving rainstorm! We may not need them, but I think we may really enjoy the convenience-we'll see if it's worth it. I'll report on this one after I do the installation and we head out next month on our trip out west.
  • In doing your prep research you may have missed these shocks - I'm giving these a try when I change out the Ford E450 OEM shocks on our 24 footer:
    http://www.koni-na.com/uploads/KONI_E350450_Cons_PR.PDF
    Koni has offered these shocks for quite time for Super C and Class A motorhomes. They just this past spring introduced these for the Ford E350/E450 chassis. I had communicated with Koni on these before they announced them for the E450 because I was very interested. The technology sounded, for the E450, like the closest thing to the active shock systems used in the racing world.
  • tpi wrote:
    The big question from me regarding Bilsteins... The impact harshness is somewhere near the stock Ford shocks? But with more control? This is my goal.
    I actually feel like the Bilsteins removed the "impact harshness" that I had with the stock FoMoCo shocks. Each expansion joint, pot hole, and so forth at times felt like I was driving something with zero suspension movement before-Just hard jolt after another. No longer does it feel like my cabinets are being jarred off their mountings while driving rough roads. This was something I was not expecting but was pleasantly surprised about.
  • j-d's avatar
    j-d
    Explorer II
    tpi - you're in luck! Here's an OP who can comment on Bil's used on a coach about your size and weight! I was shocked to see how heavy the CAT scale said our entry-level 31' with no slides is. 13,000+! So for me, the HD versions, thanks. Especially since I found we have nearly full capacity on the front axle, I would not want the Comfort type there. And I'm not ready to pay the price of a pair of Bil's for one Koni FSD. Not till I see more reports on them. Henderson's however, has weighed in in favor of those new Koni's. Thing I like about Henderson is they may sell a lot of Roadmaster, and they own SuperSteer, but they don't push every product in for example Roadmaster. They use Safe-T-Plus and not Roadmaster's competing Reflex stabilizer.
  • j-d's avatar
    j-d
    Explorer II
    A number of us have ordered Hellwig parts (and probably other suspension stuff) from SD Truck Springs.
    I've found them to be good. If you're willing to install all your own parts, you can do a full-on chassis upgrade (Shocks, Steering Center/Stabilizer like Safe-T-Plus, Sway Bars and Rear Track Bar) for well under 1/2 of having that done at retail. Retail using Roadmaster bars and paying labor is going to be around $4000.
    If you need it done at a shop, call Henderson's Line Up in Grants Pass OR and ask them who they are affiliated with in your area. That should net you a knowledgeable shop.
  • I fully agree a short coach needs help. I have '11 E450 24' and out of the box was the worst handling new vehicle I ever bought-dating back to 1977. I've gone the sway bar and track bar route and it has tightened up the handling significantly. I still have the Ford shocks and they feel inadequate. I am willing to give up some ride comfort for more secure handling as long as it doesn't beat it to death.
  • Thanks for the write up! I was wondering if Hellwig bars would be much of an improvement over stock. I will be ordering a set since I live in a very windy high desert environment. Really getting tired of the white knuckles.
  • Just had Bilstein HD's installed front and rear on our 2010 Fourwinds Freedom Elite 31r with 22,500 miles on original FOMOCO shocks. Interestingly, we had all kinds of delay/trouble from our online supplier, with delivery put off month by month from Bilstein. I finally cancelled the online purchase and found a local springs/shocks outfit who had a supplier who had the Bilsteins in two days (I didn't ask his source). Pricier than online, but the work was done professionally and in a timely fashion. Makes me wonder what is going on at the Bilstein factory.
    Now the next phase is a camping trip through MD, PA and MI in August.
    Good luck with your new stuff.
    Jim
  • j-d's avatar
    j-d
    Explorer II
    Your experience parallels mine. I installed Hellwig Front and Rear Sway Bars a few years ago and the transformation on our 31-ft/218" wheelbase E450 was amazing. From an automotive engineering standpoint, Ford took a shortcut in front sway bar mounting in 1992 that wasn't corrected till 2008. The puny OEM sway bar is even less effective because of the way it's mounted into holes in the axle instead of with real end links. The OEM rear bar is also inadequate and Hellwig provides much more rugged end links. I like Hellwig's rear end links better than Roadmaster's. Hellwig's front end link brackets don't look as exotic as Roadmaster's but they've worked fine and not come loose.
    Right now I have 2012 Ford OEM front shocks and 2002 Ford OEM rear shocks. Based on this thread, I'll consider only the HD Bilstein shocks for front and rear. I think I'm like the OP - I sense that if compromise is to be made it's toward handling and away from ride comfort, not the other way.
    2012 Ford OEM Shocks, you ask? Well, they came with a whole takeoff 2012 Front Axle setup that I bought from a 4x4 conversion shop. That gave me all-new Axles, Ball Joints and Axle Bushings, modernized Radius Arms, and much larger Brake Calipers, Pads and Rotors. The Shocks were also in the package. The pre-2008 Hellwig front sway bar works with the new style axle. Of course anybody with 2008 and later would want the part number that actually matches the year. Just saying the earlier style bar still works.
    Add Levelers if you want, I hope your research pointed you to Direct Acting and not Kick Down. That said, the Sway Bars help nearly as much on the campsite as they do on the road. Our coach is about as steady with the new bars and no jacks as it was with jacks down before and it isn't much better on jacks with the new bars.
