DaHose
Jun 11, 2013Explorer
Ok, folks. Hold on to your hats, because this post is a long one.
I just finished a few hours worth of researching and reading up on air conditioner and refrigerant type “stuff”.
What you say makes sense, Matt. I found some sites that talk about maxi frig and it really is just another brand name for HC-12a. I don't know the volume for my rig, but do I know that in my cars (I have been battling a/c issues lately) I only use 1-2 lbs.
Now for some science type stuff. I read that the self ignition temp. on HC-12a is over 1600 degrees, which is twice the heat of normal propane. HC based refrigerants are a type of LPG and burn completely clean, plus they still have the odorant that lets you know when there is a leak. As a bonus, HC-12a is made of bigger molecules than R12/R134a, so it is less leak prone. I also saw several references state that because HC-12a refrigerant is far more efficient, you can use as little as 35% of the charge required for the same R12 based system, so you use way less volume than R12. Also, people said they found that the lower volume of gas moving, results in less drag and improves mileage (we talked about that York robbing me of some mpg), so retrofitting an R12 system with HC-12a should yield a performance increase.
On the other side of the fence, R134 is both toxic and corrosive and it actually is highly flammable when mixed with the oil inside your compressed system. R12 also burns, but it also breaks down into phosgene compounds which are HIGHLY toxic.
The biggest risk everyone seems concerned about is the condenser full of LPG in the front of your vehicle rupturing in a crash. However, unless there is an open flame at that point, it will disperse almost immediately. If it does ignite, it will cause a great big puff when it ignites and the remaining compounds are rendered inert. The worst case would be a sealed system caught in a fire and getting hot enough to burst. That could be quite ugly, but I was unable to find a single reference to studies documenting HC refrigerant fire/explosion rates in automotive applications. Mind you that an R12/R134A system could also burst when exposed to fire. That would also VERY bad and the remaining compounds would be highly toxic.
I looked, but couldn’t find anything about commercial based systems or recalls of HC refrigerants and those applications have been using HC based refrigerants for a very long time.
I understand the concern over putting some highly flammable gas into your A/C and having it near your SMOKING hot engine parts, but I also understand the argument for why HC-12a based refrigerants can be used safely. Canada allows the use of HC-12a in production automotive systems (they are safety crazy like we are) and I don't find any statistics or numbers one way or the other about its safety record in the auto industry. In the USA, the “legality” of using HC based refrigerants varies, but it is legal in California. So if we are using it here in Ca. and you don't hear about constant class action lawsuits or recalls, that is a strong indicator of a good safety record.
I will keep digging for more information, but HC-12a really does look like an ideal refrigerant that can replace whatever you are running and is compatible with whatever parts and oil you have in your existing system.
Jose
Jose
