trop-a-cal
Jun 17, 2015Explorer
Yes change the fuel pump, but it requires the tank to be dropped as it is on the top. Check the tank for rust also. The pumps have plastic components that don't last forever, and the pump itself is cooled by the gas, so don't run it standing still with less than a half tank. There is a video showing the entire procedure on line that will help you, showing all the connections. Make sure you use high pressure fuel injection line as it last longer, even if you have non fuel injected engine. Then there is a fuel injection rail regulator that probably needs replacing too.
