harley-dave
Sep 17, 2018Explorer II
jimx200 wrote:Yep, happened to us also. Unlatched the dog house, checked seal and re-attached; all was better. We also have the coach heater that uses the engine heat while you are driving to warm the coach. If the fan switch (on lower right part of dash) is bumped to ON (Hi or LOW) it can get very warm in the passenger seat as the vent is located on the floor right behind the seat on the right side.
Bingo! Our Ford chassis with the V10 had the same hot floor/warm seat issue. Discovered our dog house cover was not correctly sealed. What completely fixed the heat issue is we lined the inside of the dog house with the silver reflective peel and stick insulation. We also pulled up a section of carpet where your feet rest and no more problem. A easy job.
Dave
