Handbasket
Jul 30, 2014Explorer
Alta, re adding rear air bags... I don't know how well this will translate to the E-450, but they sure improved the ride on my 2500HD Silverado-chassis'd Tiger (19' C). Loaded, it's near max GVW, and the thick heavy short rear leaf spring was pretty much always engaged. There was a distinct 'bang-thump' jolt as the rear hit expansion joints, let alone real bumps. I had an older AirLift compressor and dash controls, and bought the 5K# bag-only kit to fit my chassis. Just 20-25 psi of air smoothed out the ride a bunch. The jolt was replaced by a gentle bounce.
But first check your axle weights at a truck scale, and research needed tire pressures. Michelin has a good, easily pressure/load chart for E-range tires online. If you happen to be running 80 psi 'because it says so on the sidewall,' that's part of the issue.
Jim, "Mo' coffee!"
Jim, "Mo' coffee!"
