Sam_Spade
Jan 20, 2018Explorer
rowekmr wrote:
The MH is currently sitting at RV campgrounds with both battery disconnects on.
No real need to run engine or gen while it is just sitting BUT there is a need to keep the batteries charged.
If you are parked in a campground that has power, just plug it in for 24 hours once a month.....and close the battery switches to charge.
If you don't have access to shore power, then run engine AND gen once a month for at least a half hour to get up near normal operating temperature AND to charge the batteries. Operate the disconnect switches when done.
While the engine is running, move it 12 inches to help prevent flat spots on the tires.
38,782 PostsLatest Activity: Sep 10, 2026
