Sam_Spade
Jan 20, 2018Explorer
et2 wrote:
However I do at the end of each month during this period start the generator and put a load to it for 2-3 hrs.
Unless it is REALLY COLD out, it will come up to full operating temperature in a lot less than 2 hours.
If it is REALLY cold out, just leave it alone until the weather warms up a bit......and then running it 30 to 45 minutes will be plenty. If you don't believe that, just remove the cover panel and feel around on the inside a bit (being careful not to BURN your hand).
38,782 PostsLatest Activity: Sep 10, 2026
