rowekmr's avatar
rowekmr
In Winter Storage, Should I Run Engine?
The MH is currently sitting at RV campgrounds with both battery disconnects on. I was told by previous owner he would start his occasionally during storage. I thought this isn't good unless you drive it also. Should I just let it sit or periodically start or drive it?
  • Disconnect your batteries , put a trickle charger on the batteries or take them inside where it is warm. Do Not start the engine just for kicks,unless you can drive 25 miles or more. Keep the fuel tank FULL!
    If you take the batteries out , take a picture or make a detailed diagram of all wiring!
    Just my opinion & long time experience !
    Siggy
  • Remember, on most MHs, the house battery disconnect does not kill everything so the batteries will eventually die if you don't pull the negative battery lead.
    Bill
