bluwtr49
May 24, 2016Explorer II
I had a similar problem when I put in the parking pad alongside the garage. The dip itself wasn't too bad but the coach overhang was allowing the hitch to hit the crown of the road itself. Backing in may have not been and issue but I never tried that. In my case I filled in the low spot with 2-3" gravel than leveled it with decorative rock ~1/2". As far as water, I just let it run over that portion. No problems for the past 5 years. That pad is no longer used since I built the barn on the other side of the house but it's still there.
I suspect how you resolve your issue will largely depend on where you live since, most often, that dip may not be on your property but part of the roadway. You might check and see if you can even do anything without running afoul of the local authorities.
As far as raising the coach, some leveling systems will allow you to manually raise the coach and still be able to move it....gently.
38,780 PostsLatest Activity: Nov 22, 2015
