UltraKen
Jun 30, 2013Explorer
I use the 125psi compressor that the previous owner installed. If I ever have to replace it I'd spend a few bucks more for a 150psi unit. Mine isn't bad but it recycles often and a little more pressure would increase the time between cycles.
Here's the inflator:
This is a very accurate gauge. I added a quick disconnect fitting so I can just use the gauge for checking without unreeling 50ft of air hose.
38,766 PostsLatest Activity: Jan 10, 2026
