Hikerdogs
Jun 30, 2013Explorer
Rule of thumb is the compressor needs to put out at least 25 lbs more than the tires require. Even then inflating the tires will be a bit slow. The 150 lb compressor is a good choice if you have room for it.
We have a cheap walmart one that goes to 115 lbs. It wasn't our first choice but it was available when we had to have it. It worked fine on our old motorhome that only used 85 psi. The new motorhome uses 90 psi to 95 psi depending on how we load it. We haven't had to try it yet. Hopefully it'll do the job if necessary.
38,766 PostsLatest Activity: Jan 10, 2026
