mlts22
Sep 09, 2013Explorer II
The 110 volt water heater uses 1400 watts, but the good thing is that since it uses a resistance element, there is no inrush current.
If I chose to run this off batteries, that would be ~150 amp-hours I'd need, assuming the losses from an inverter. So, if I ran the water heater from the house batteries for 10-15 minutes, that is doable without firing up a generator, although I will have to recharge the batteries that day if I didn't have solar available.
So, depending on what the Travato's battery capacity is, the water heater could be run for a brief bit just on batteries to get things hot enough for a shower, but not for too long.
