gsf35099
Jan 02, 2018Explorer
Executive wrote:
It was REALLY cold here in Arizona. Got down to 55 degrees last night. We thought about turning the heater on but decided against it....:W...Easiest solution to your "problem" is to drop a 60 watt incandescent light in the bay. I used a chick light that worked very well. Any feed store or hdwe store will have them and you can clamp them anywhere in the bay.....Dennis
Chick light
Thanks Dennis. As said, not sure how y'all are handling that brutal cold weather. :)
I actually found a great little heater from Wally-world for $9 that fit perfectly with fan and thermostat and the 2 output settings (750 or 1500). Set it to 750w with a thermostat ac plug on the cord in the bay and at 4 degrees this morning had running water. :B.
Also picked up some aluminum bubble insulation and tape to do some upgrades when we get back home in the heated garage where it is much nicer to work. :B.
